Hi,
We have managed to get hold of some more refurbished coolers from Corsair. These products are boxed and have all the accessories included. They come with a 1 year warranty at a big discount. So if you are looking for a bargain as the rest of the prices are going up hopefully this cooler will help you.
The saving on this cooler will allow you to buy some extra components maybe some Corsair ML fans or a better CPU your choice.
Corsair Hydro H105 240mm Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished* @ £79.99 inc VAT https://www.overclockers.co.uk/cors...ooler-manufacturer-refurbished-hs-03b-cs.html
Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ AM2 / AM2+ / AM3 / FM1 / FM2, 1 Year Warranty
Installation is easy, with an all-new mounting bracket that provides quick, tool-free assembly. The three included red, grey, and blue accent rings let you match your H105 to your DRAM and motherboard color scheme. And, like all Hydro Series liquid CPU coolers, the H105 is completely self-contained, with no filling or maintenance required.
Extreme CPU cooling performance
The extra-thick 240mm radiator increases surface area significantly for superior heat dissipation. Take advantage of your case’s 240mm radiator mount and use your case to its fullest potential with a massive CPU cooler.
Protect your hardware and increase your CPU’s overclocking potential. Keep your CPU frosty at stock speeds or eek out that extra hundred megahertz of clock speed.
Dual SP120L fans with PWM control for customised cooling performance SP120L high performance, high static pressure fans are optimised specifically for radiator usage.
All-new mounting bracket design for easy installation with thumbscrews and snap-in head mount ring design for quick and easy installation on AMD and Intel processors.
Includes three colour accent rings to match your H105 to your motherboard
Default metallic grey, and added red and blue coloured rings to match your Corsair Air Series fans or other motherboard, memory, or GPU colour themes in your case.
Specifications:-
- Radiator Dimensions:- 270mm x 120mm x 38mm
- Fan Dimensions:- 120mm x 25mm
- Fan Speed:- 800 - 2700 +/- 10% RPM (PWM)
- Air Flow:- 73 CFM
- Static Pressure:- 3.9 mm-H2O
- Noise Level:- 37.7 dB(A)
- Part Number:- CW-9060016-WW
Only £79.99 inc VAT.
ORDER NOW
View all AIO coolers HERE
Specifications:-
- Air Flow:- 73 CFM
ORDER NOW
