Hi,
I am deciding between Corsair AP120 or SP120... Quiet or Performance... PWM or Non-PWM.
What I was wondering is inside the Performance edition you get "Voltage step-down adapter for lower speed operation".
Do these basically turn it into the Quiet edition or do they only put it down slightly?
I mainly ask as I was swaying towards the Quiet edition but I can get the Performance edition a bit cheaper and if that was the case would just go for them.
Thanks
Thanks
