Hello, ve had a corsair ax760i since xmas. Worked perfectly fine when i got it and has done for the past 3 months. I got home from work today to turn my pc on and nothing... Looked at the PSU and the there was a red light on the psu (normally where the green one is) Obviously seeing this made me unhappy anyway. I removed all the cables and pressed the self test button and it ran fine so i did a few tests and worked perfect. Plugged all the cables back in (i use the red braided corsair kit) andnow its come on fine as if there was no fault. Im a little worried now though as to what the fault was? never had this problem before and the pc has been perfect no issues, shut down fine last night after playing a game and i have never done any overclocking on my pc everything is default. Could you please advise me on what i should do? should i be worried or should i wait and see what happens
System Specs:
Corsair Dominator GT 16Gb, Windows 7 64bit, AMD Phenom II x6 1090t Black Edition 3.20Ghz, Asus Crosshair IV Formula DDR3 Motherboard, MSI Radeon 290x 4GB, Corsair ax760i, Corsair H105 cpu cooler
Im really looking for some help here had a bad week and work and come home to the pc not working D: Its all working fine now but im still unsure...
Update it broke again.. died half way through a game of Dota.
When the pc starts up now it says CPU fan error?
System Specs:
