22 Dec 2012 at 11:14 #1 RizGB RizGB Associate Joined 2 Mar 2010 Posts 502 Does anyone know if i will have problems installing this psu would i need any adaptors. Going in a corsair 500r case. Cheers
22 Dec 2012 at 11:40 #2 Lemin Lemin Soldato Joined 8 Jul 2009 Posts 3,106 Location Folkestone No problems at all. edit u may need.... Akasa 8-Pin 30cm PSU Extension Cable (AK-CB8-8EXT) [AK-CB8-8EXT] £4.79 inc VAT http://www.overclockers.co.uk/showproduct.php?prodid=CB-022-AK&groupid=1929&catid=1979&subcat= Last edited: 22 Dec 2012
22 Dec 2012 at 11:48 #3 OptimaLnrg OptimaLnrg Soldato Joined 9 Mar 2009 Posts 2,877 Location - will go straight in
22 Dec 2012 at 18:24 #4 Sasahara Sasahara Soldato Joined 12 Feb 2009 Posts 4,424 If your routing the 8pin EPS cable round the back of the case (Which you should) you will need the PSU Extension Cable Lemin suggested.
23 Dec 2012 at 13:51 #5 mick4545 mick4545 Associate Joined 29 Dec 2007 Posts 803 Location Hereford The PS comes with an 8 pin extension.
23 Dec 2012 at 14:17 #6 Sasahara Sasahara Soldato Joined 12 Feb 2009 Posts 4,424 mick4545 said: The PS comes with an 8 pin extension. Click to expand... Got a source for this info? I've had 2 AX850s (over a year ago) and they came with 2 8-pin EPS connectors, no extensions.
