- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
The new C70 Vengeance cases have arrived from Corsair today!
Corsair Vengeance C70 Midi Tower Gaming Case - Military Green @ £119.99 inc VAT
When it’s time to take your competitive gaming on the road, the Vengeance C70 mid-tower PC case is a great choice. It’s crafted out of solid steel and made to survive trips with less wear and tear, and the ergonomic carry handles help you move your gear with confidence. High-performance gaming hardware requires high-performance cooling. Vengeance C70 is equipped with three 120mm fans out of the box, with mounting points for seven more to meet your exact air cooling demands.
Vengeance C70 is also outfitted for liquid cooling upgradeability. You get 240mm radiator compatibility on top of the case, and if that’s not enough, you can remove the lower hard drive cage to fit a second 240mm radiator for a dual-loop setup.
A case is as much a part of your armory as any other component. With internal USB 3.0 connectors for modern motherboards, native SSD compatibility, eight expansion slots and room for long graphics cards, the C70 stands ready to take on any challenger.
Easy access side panels come off with quick-release latches. The optical drive bays and 3.5” hard drive bays are tool-free. Thumbscrews secure your graphics cards, and the hard drive cages can be easily removed for better airflow or additional expansion room. Cable routing tie-downs and built-in clamps keep your system tidy.
- Room for 2 x 240mm Radiators
- Tinted Side Window with dual fan mounts
- Motherboard Support: ATX & mATX
- Material: Steel
- Expansion Slots: 8
- Drive Bays: 3 x 5.25" & 6 x 3.5"/2.5" bays
- Cooling: 2 x 120mm intake fans and 1 x 120mm exhaust fan
- Front I/O Ports: 2 x USB3.0 / 2 x Audio
Only £119.99 inc VAT.
ORDER NOW
Corsair Vengeance C70 Midi Tower Gaming Case - GunMetal Black @ £119.99 inc VAT
- Material: Steel
ORDER NOW
Corsair Vengeance C70 Midi Tower Gaming Case - Arctic White @ £119.99 inc VAT
- Material: Steel
ORDER NOW
- Material: Steel
ORDER NOW
- Material: Steel
ORDER NOW
- Material: Steel
ORDER NOW
