corsair c70 front panel
First remove both side panels.
Then if you run your fingers down the edge , behind the front panel, you should feel some tabs (3 on either side. Top, middle and bottom).
Gently press them in and push out at the same time.
Don't have any experience with this case, but hope this helps. :)
^ above , remove both side panel and there's 3 clips on each Side , push down on each tab in parallel , two top , two middle then two bottom to easily release the front ... Spot on from a guy that's never had the case ;)
