Corsair c70 side window
30 Apr 2012
London
I would like a clear side panel for my corsair c70 however I don't have tools to do so is there a good guide to doing it as don't wana mess it up
In the meantime, have you tried Youtube?
Edit# I've just had a look and there seems to be a lot of guide to REPLACE the window. Would it not be better and simpler to buy the replacement door panel?
It is super easy. You cut a hole, cust a piece of plexiglass (about 3mm thick). Make it about an inch bigger than the hole and fit it with doublesides tape. Voila a new window is born. You can also buy a piece of window rubber and make the window as big as the hole and fit it in the rubber. So many ways. Also you can fit it ON the case with screws or inside the case with screws. Enough ways, whatever suits your look.
I know, so you order a piece of plexiglass in the correct size. 3 mm plexiglass. Size is up to you. Very easy to work with.
I've been through the past 18 months of CPC's and can;t find the article. I wish they had a blooming index system so you could look up which edit an article was in!!!
I went for the smoked look. Pretty cool when you have lights.
Did you provide the company with the measurements and then fit it yourself Rossi?
The fitting looks really clean!
Yeah, i had a CAD design done for it and then sent it to them and told them i wanted smoked.
I will get the design and see if i can host it up for other's to use.
