Corsair Carbide 600C Rear Filters
5 Mar 2014
South Shields
Hey everyone, i have the titled case and for a little while now i've been meaning to put some dustfilters on the rear of the case. I just don't know which are the best and not sure if i can even find the one for the little part above the rear fan.
I'm after a Dust Filter for the rear fan and the part just above it, not sure if that area has a name but if it does i'm not aware of the name sorry.
If i have to make my own i guess i will have to but i was just hoping i could maybe find someone who knows which ones i can purchase.
Thanks.
The rear fan should be exhaust so doesn't need a filter and if you just make sure you have positive pressure in the case (more fans as intake than exhaust) then the 600c should be fine for dust filters.
If you still need filters though, demciflex make some decent ones you can use for the fans but you'd have to diy the rest - womens tights usually work (seriously :p)
I managed to buy one for the rear fan but its just that vent above, it doesn't look like its bringing dust into the case it just sits on the outside on the vent itself, makes it look nasty. Do you think it would be ok to just block it off to help with positive pressure? As i currently have 3 intake, 2 exhaust.
