Corsair Carbide Series 275R Tempered Glass
1 Nov 2014
Leeds
Hi folks.
Having a problem installing
Kingston SA400S37/240G SSD A400 Solid State Drive (2.5 Inch SATA 3), 240 GB in the ssd bays in the case listed above.
The ssd won't clip into the bay seems a little bigger?
You often need to spring the frame put a little until it lines up with the screw holes. Does the tray have little pins that go in the screw holes of the SSD?
Do you mean the trays in the rack at bottom left of that photo? Or the SSD holding plates at top right.
The SSD plates, you remove and screw the SSD onto it from the rear then remount.
The SSD goes ON that panel, on the "outside" of it. Screwed in through the main plate. I had exactly this problem for ages, trying to wedge the drive into the wrong side!
Try it this way:
