I've just purchased a new Corsair case (here) and intend to install the Corsair Hydro H100i (here) for some water-cooling action.
However, I've just looked at the Corsair website and it says:
Then on the same website where the Hydro H100i cooling system is shown, it says:
I'm speculating that there wouldn't be any issues mounting the H100i in the case if there's 40mm difference? I'm asking because I don't really know what the fixings look like and never installed one before.
And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel.
Do you have a PC case that supports a top-mounted 240mm radiator?
