- 8 Sep 2008
- Birmingham
Gahhh. Im hoping someone can clear up some RAM issues for me. Ive spent 3 hours searching for an answer and im even more confused now then I was when I started. I want to get 4gb more RAM of the stuff I have in my pc, however I cant figure out what is in my pc!!! Ok with my original rig I ordered from OCUK i was supposed to get 4GB of this RAM http://www.overclockers.co.uk/showproduct.php?prodid=MY-148-CS&groupid=701&catid=8&subcat=817
As you can see the model/part number is TWIN2X4096-8500C5DF.
Now everest and cpu-z is giving me a different model/part number: Corsair Dominator CM2X2048-8500C5Dand cpu-z tells me this is pc-6400 NOT pc-8500 as I was supposed to get with my original £1200 order.
However....I found a Corsiar spec pdf that says 4096 Megabytes of DDR2 memory in the form of Two matched CM2X2048-8500C5D modules = TWIN2X4096-8500C5DF (both RAM models looks identical)
Can anyone help me figure out if I have what I paid for installed and if it is indeed pc-8500 as it is supposed to be?
The sticker should clear everything up - it has all the details on it.
