Corsair Confusion!
29 Jul 2021
Beverley
Hi folks,
I'm doing a new build and I'm really confused with my fan system!
I have, 6 x LL120 fans (2 x 3 pack that come with a node pro and a hub in each pack)
Also I have the H150i 360 cooler with 3 fans on (Comes with a Commander Core)
I have a B550-F motherboard and I'm not sure how to connect it all up with all the different hubs, nodes, core and headers.
Can anyone shed some light on this for me? I have a Lian Li O11 dynamic.
Do I just connect the aio to the commander core and a USB 2 header and the CPU fan header, then connect a node pro to a USB header and an RGB header, plug the hub into that node and then plug the remaining 6 fans into the 6 slots on the hub?
Thanks (If you understood that hah)
That sounds 100% right.
That sounds right, except for the part about the RGB header. Typically that will be controlled via the USB header, in Corsair software, so no need to plug it into the mobo RGB header.
