Corsair cooler
25 Feb 2010
Shepperton
i am going to buy the OcUK bundle with the Corsair H50 option but I'm a little concerned with what I read in a review:
"Pretty much you use these four screws (supplied) and push them through the chassis, fan and radiator. This mounting system is unfortunately far from ideal. Chassis' tend to differ, should the chassis be thick or have another mounting system design for the 120mm fan, these screws will not fit as there isn't any clearance."
Will the radiator/fan fit easily into the back of the Akasa Eclipse-62?
From what I've heard the H50 is very well designed. Worst case scenario is you go to Homebae and buy some longer M4 screws costing ~£1. If you're happy with the cooler go for it, I wouldn't worry about not being able to mount it in your case.
thank s for the advice. The review also says that the supplied fan must blow air inwards. Is this a big issue?
They give you a few options. They only suggest that you mount it that way.
I do intend to mount mine on a 140-120mm shroud at the top of the case. Once I get the time!
