- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair A70 High-Performance Dual Fan CPU Cooler (Socket AM2/AM3/LGA775/LGA1156/LGA1366) @ £53.99 inc VAT
If you’re serious about high-performance computing, you already know that you’ve got to keep your PC’s CPU cool. Cooling not only gives your CPU the headroom it needs for reliable overclocking… it can also extend the life of your valuable investment. And, you need something that not only significantly outperforms your CPU’s stock heatsink, but does it quietly.
The Corsair Cooling A70 High-Performance CPU Cooler uses advanced thermal engineering technology to deliver superior air cooling performance: four 8mm copper heatpipes directly contact your CPU, and the surface is planed to increase heat transfer efficiency. Dual speed-selectable 120mm fans, mounted on rubber studs, spin quietly in a push-pull configuration for optimum airflow.
Protect your valuable investment in your CPU, and enjoy faster overclocking performance.
- Compatible with Intel and AMD systems
- Four 8mm copper direct-contact heatpipes
- Aluminum fins
- Low-noise, low-vibration 120mm fans mounted on rubber studs
- Selectable 1,600 or 2,000RPM allows you to select the cooling performance you want
- Air flow: 50 - 61 CFM
- Noise level: 26 - 31.5 dBA
- Two-year warranty
Only £53.99 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1156/LGA1366) @ £42.99 inc VAT
Excessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away.
You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.
- Three 8mm copper direct-contact heatpipes
- Aluminum fins
- Low-noise, low-vibration 120mm fan mounted on rubber studs
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want
- Two-year warranty
Only £42.99 inc VAT.
ORDER NOW
- Aluminum fins
- Two-year warranty
ORDER NOW
- Aluminum fins
- Two-year warranty
ORDER NOW
