I am just specing up a new build as follows
13900KF
240mm AIO cooler (brand TBD)
RTX 4090 with 360mm rad (this one https://www.overclockers.co.uk/giga...orce-24gb-gddr6x-pci-express-g-gx-1fg-gi.html)
I know the 680X can fit a 360mm rad up front so the GPU rad will go here. However looking at the dimesnions and clearances I don't think you can then get a 240mm in the roof or the bottom if you are running a push pul config on the 360mm GPU rad. So plan B was bin off push pull and just use push. So working out clearance that would be 25mm (fan depth) + 30mm (rad depth, this is a guess as I can't find the specs on the aorus radiator anywhere, but eyeballing it looks like 30mm)
So that would be a total depth of 55m, call it 60mm incase of wierd tolerances on the rad.
Looking at pictures of the internals on the 680X and searching for vidoes on youtube I haven't seen any builds featuring a 360 upfront plus a 240 either in the roof or the floor ?
I guess plan C could be to ghetto it and mount the fans for the 240 externally under the roof glass and then just have the rad inside which shoulkd theoretically leave the space required.
If anyone has done a build in a 680X with a 360 and a 240 wouldn't mind seeing some pictures
13900KF
