Corsair CS750M Power Supply
They are not "extension" cables, i.e you dont plug them into the ends of the existing PSU cables, these plug into the PSU body directly.
Not all PSU (even from the same manufacturer) have the same connection type, that is why they only fit what Corsair say they do.
Also if you look at the part number and compare to Corsairs page - http://www.corsair.com/en-gb/profes...leeved-dc-cable-kit-type-3-generation-2-white
AX Series, AXi Series, CXM Series, HX Series, RM Series, TXM Series
I think you would be best asking the Corsair rep (greybeard) who will be able to find out if they will fit and work.
