Corsair CX 750 Semi Modular - Crossfire?
17 May 2004
Home
Hey everyone
Will a Corsair CX 750 semi modular be suitable for running two Radeon 7950s in CF? Or should I be looking at a model other than the Builder series? PC spec is in my sig :)
It meets the requirements. Wouldn't recommend if you were buying new but if you already have it might as well. How long have you had it now?
Thanks for the replies. I made the decision to go for a Corsair RM850i instead. I've never been one for buying cheaper components but the price on the CX seemed too good to ignore when I saw it! I thought better of it in the end :) Spending the extra on the 850w should future proof me a little more. I'm currently running a TX650M that I've had since June 2013 but it isn't enough to power the two 7950s. That's why I need the upgrade :)
Ok cool, I've changed my order to an EVGA SuperNOVA 850 Gold. I know you recommended the Platinum but I think that the Gold should be absolutely fine for my needs. My PC isn't on all day.
