- 25 Aug 2023
- UK
Yello! Bought a nearly-new Corsair CX600 and tested it with my multimeter (PS-ON shorted to GND) before putting it into my Lenovo Booststation eGPU enclosure (ITX type format).
On testing without load, fan spins up as expected, all voltage rails (on MoBo 24-pin, PCIE 6+2 pin & CPU 8-pin connectors) test fine within ATX tolerances...
When I connect the Corsair CX600 to the eGPU, the fans (PSU fan + enclosure fan) power on but that's all that happens... Checking voltages now, the MoBo 24-pin connector's 12V and 5V supplies are within tolerance but the 3.3V is well under spec at a max of 2.4V! PCIE and CPU voltages all test fine.
The eGPU contains a Sapphire Pulse Radeon RX 6600 XT gfx card with a single 8-pin power connection; fans don't spin up, eGPU is connected to my PC (via Thunderbolt 3) but Windows 11 doesn't detect the card.
This problem does not occur with the original eGPU PSU, a crappy 500W LITEON. Everything works. Only issue is some kind of signal noise on high demand (AAA game title) which causes stuttering in-game (other people have sorted this out using a better PSU).
If there's a bad ripple problem I don't have a scope to check that. I guess the low CPU 3.3V supply is the culprit?
Not an electronics guy so pardon my ignorance: is this likely a simple capacitor replacement issue for the 3.3V rail, a controller issue or something else? Could this be a problem with the SENSE pins?
Might it be worth doing a little DIY or should I just chuck this?
Thanks.
(The seller of the PSU, who seems decent and has a 1000% eBay rating, refunded the sale without my having to send the unit back. I wonder if the unit was damaged in transit.)
Thanks.
