Hi all,
Corsair Dark pro RGB gaming mouse, have two problems with it at the moment.
Battery - it is about 2,5 times thicker than it should be
Switch for button under scroll wheel - not registering press..
Battery - not found any reference to any number or code found on original battery: SH703448(1lCP7/34/48 - Intertek 5006685. Only link I found to something similar is: https://www.ebay.co.uk/itm/184854611045?epid=1260416688&hash=item2b0a318465:g:3VoAAOSwn0xjhbH5 with 3pin-1mm plug, any idea if that'll work?
Switch for scroll wheel - it is clicking, I can hear it, but mouse does not register it's being pressed and not rotating picture in Google Earth or Cities:Skylines (those are two titles I was able to do it previosly in, but not anymore) - stupidly not taken picture when disassembed mouse, but seems like simple dip switch with two prongs at back.. You can see it at timestamp 6:48 in this video:
- blue button on a square-ish board just below wheel.
What are my options here? Battery costs 10 pounds, but I don't really use wireless, so meh.. for switch - my soldering skills are reasonable, but have no clue if that's something straight off the shelf and if yes - what to ask/look for?? not my area of expertise..
