dont know about the ds4 but it is reccomended on the corsair site for use with the asus p5b which uses the 965 chipset. The problems on the ds3/4 seem to be with memory voltage above 1.8 (default)
i'm using that ram and am having no end of problems, i have 4 1gig sticks and the system will only work with one specific stick, with the other three, pc turns on... pc turns off... pc turns on... you get the picture. i'm trying desperately to find a solution cos 3gigs of useless ram is not good!
