** CORSAIR DDR4 NOW AVAILABLE: OcUK FIRST AGAIN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK does it again and has Corsair DDR4 now available for pre-order, check them out here:-
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (CMD16GX4M4A2666C15) @ £319.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 2666MHz (PC4-21300)
- CAS Timings: 15-17-17-35
- Voltage: 1.20v
Only £319.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £399.95 inc VAT
Specification:-
- 2800MHz (PC4-23000)
- CAS Timings: 16-18-18-36
- Voltage: 1.20v
Only £399.95 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C15) @ £239.99 inc VAT
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There’s XMP 2.0 support for trouble-free automatic overclocking. And, they’re available in multiple colors to match your motherboard, your components, or just your style.
Specification:-
- Voltage: 1.20v
Only £239.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (CMK16GX4M4A2666C15R) @ £239.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Black (CMK16GX4M4A2800C16) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £299.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Blue (CMK16GX4M4A2800C16B) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Red (CMK16GX4M4A2800C16R) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Some nice looking kits from Corsair and OcUK brings you them first!! :)
Haswell-E and the X99 platform will use DDR4 as it is a central part of the Architecture.
DC cannot use DDR4 natively.
That and the Crucial Ballistix were faster in frequency while having tighter advertised timings than the above. The Dominators look like bad value by comparison.
The blue and red kit images look like bad photoshop colour changes rather than actual product images ;)
And here we go again...with RAM costing as much as the CPU. Going to wait a bit until prices come down and skip a gen, i mainly game and at a low res so x99 (6 core, ddr4) just isnt worth the outlay at the moment if i had 1.5K to spare i would be all over it though :)
Wait a couple of years and we'll have these kits for less than a £100! DDR3 is still good for some time to come yet.
Can't be any comparisons as the haswell-e is a new chip on a new chipset.
Even if you could use the same chip the chipset and bios would be different so direct comparisons will be hard.
