** CORSAIR DOMINATOR DDR4 3200MHz!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair are winning the speed race with DDR4:-
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £499.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 3200MHz (PC4-25600)
- CAS Timings: 16-18-18-36
- Voltage: 1.35v
Only £499.99 inc VAT.
ORDER NOW
Were also expecting a 3300MHz soon as well from Corsair!! :eek:
Sorry but that price is ridiculous, I know it's not your fault but it's hardly any faster than low timing 2133mhz DDR3 for most tasks.
lol yeah im not quite sure why this was posted in the Monitor section.
Maybe just to show that you could get a 4k monitor for the same price or less :D
All new items/deals etc are spammed in nearly every section (its nothing new/recent), the problem is the comments are not linked so you have multiple convos going on.
