** CORSAIR DOMINATOR DDR4 3200MHz!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair are winning the speed race with DDR4:-
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £499.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 3200MHz (PC4-25600)
- CAS Timings: 16-18-18-36
- Voltage: 1.35v
Only £499.99 inc VAT.
ORDER NOW
Were also expecting a 3300MHz soon as well from Corsair!! :eek:
Gibbo are there any SKUs from brands other than Corsair with 3200Mhz+ on the horizon?
Yes G.skill, Avexir, Kingston and Patriot will have 3200MHz+ stuff.
Most DDR4 can hit 3200-3600MHz, it clocks very well. :)
LAtencies have gone through the roof to hit those speeds.. I would not expect it to bring about much of a performance increase if any going to them if they have to push the other timings out so much
