- 10 Jan 2022
- Birmingham
Anyone got these speeds on the Maximus Z690 Hero ?
Have you tightened the timings manually and seen any improvement?XMP II
DDR5-5600 36-36-36-76-1.25V-1.25V
Is that what you mean?
No I decided to leave as is given that DDR5 is relatively new and see how I get on. So far perfectly fine.Have you tightened the timings manually and seen any improvement?
Fair enough.No I decided to leave as is given that DDR5 is relatively new and see how I get on. So far perfectly fine.
Fair enough.
Buildzoid is overclocking his ram to DDR5-6800 CL34, which is insane. I don't know if that would put distance between it and a good kit of DDR4 but it's good to know that you can overclock some ktis to the high end.
