Corsair Dominator GT 2000mhz 8-9-8
Man of Honour
13 Nov 2009
Northampton
I've developed a bit of a ram clocking addiction.
Looking for something cheap that is going to do 2200mhz tighter than my Mushkin Radioactive Cas6 kit.
Whats the likelyhood of the Corsair Dom GT being better binned and be capable of benching Cas 7 or 8 on air (Current Mushkin does 9-10-8-26)
Going upto 2400mhz would be nice but I can't go higher than 2222mhz with this chip without making a huge sacrifice on clock speed.
What are your sub timings mate??
TRRSR 4 and TWCL 7 are just as important as CL. CL7 2400 on teh Corsair is probable but probably not with the timings I list that tight. With PSC on Air keep TRAS around 28 and TRFC 96 tune all others first.
SuperPi run and subs in the image.
A good set of PSC will go much tighter at 2400mhz. 7-11-7 TRRSR needs to be 4 if at all possible. Cant your seconds come down also. 5,96 7936, 10,5,25.5,5,7 optimal at around 2400.
I must have a pretty poor set of PSC.
I can run Pi with ram @ 2400mhz if CPU is around 4ghz, if I push any higher on CPU it doesn't boot (Haven't tried it with more than default VCCSA yet) was doing 9-10-9-28 1T 96TRFC @ 2400mhz though.
little better pushing the vccsa. How big of an affect does vdimm have on imc,I have been benching with 1.84v but the ram is fine day to day with 1.7v 2133mhz 9-10-9.
Does pushing larger vdimm reduce the potential of the chips imc
