Corsair Dominator-GT Module Dead!
29 Jun 2009
Milton Keynes
Need some advice from Yellowbeard please!
I have a stick (one of three) of Dominator-GT TR3X6G2000C8GT which has died.
The bios reports just two sticks and while MemTest86+ reports the slot is occupied it can't test it!
I've been looking at the RMA section of the Corsair site and the module doesn't seem to be listed! How do I get round this?
Do I have to return all three modules?
Thanks.
Chris
The part number has been changed to CMG6GX3M3A2000C8. Try switching the modules around in the board so that the suspect module is in a known working MOBO slot. It's possible you have a bad slot or bad memory controller on the CPU.
If you decide you need an RMA, use THIS LINK and we'll replace them ASAP. Return all 3 modules.
Thanks for the quick reply!
I inadvertantly checked the slots when trying to establish which module was faulty.
Should I use the (bulkier) original packaging?
Do I also need to return the cooling fans which were part of the original purchase?
Well I duly sent it off last Monday the 18th and it was duly delivered Wednesday morning. I had an email Thursday confirming receipt for RMA
1144150. The email also mentioned to allow for an additional 5 working days.
So when, roughly, should I expect to hear something?
Also, are there shortages of this particular module since I note OC are out of stock.
Thanks
