From here (granted its different memory being used)
http://www.clunk.org.uk/forums/reviews/8665-corsair-dominator-airflow-fan-mini-review.html
I tested with Gigabyte GA-EP45-EXTREME Using Crucial Ballistix 8500 Ram was running at Stock 1066Mhz Voltage at 2.18v in bios around 2.24v actual.
Tested running Prime Large FFTs
I have a digital temperature sensor attached to a T-Balancer bigNG with Dual Modethis is attached to the inner side of the module0 with a velcro sticky patch.
Ambient temperature in case is 25C
With Corsair Cooler
The sensor Temp can be seen on the right hand side...
Idle Temp is 28C Final Temp 33.5C , a gradual escalation over the 20 minute test.
Running without fan
I had intended to run the test for the same duration but quit when the temperature hit 45C
So change in temperature on load is 11.5C , not to be sneezed at , especially running Micron
If you overclock I would recommend cooling your ram.
I think Corsair have the best cooler I've used.
The only criticism I have is lack of information about the conductivity of the legs.
Noise might be an isue to some , but personally i'm very happy with it. After 2 years of use my old unit is noisy at start up, but then quietens down. New units are much quiter.
