Corsair Fan?
i want to keep my case quiet so AF120 QE?
Depending on how you are managing your fans, you can keep any fans you use quiet. My penetrators are running 300rpm :)
Or if you are not worried about aesthetics:
YOUR BASKET
1 x Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan £15.98
1 x Akasa 120mm Piranha high performance PWM air ripper blade fan £13.99
1 x Enermax T.B.Silence PWM UCTB12P 120m Fan £11.99
1 x Prolimatech Ultra Sleek Vortex - 120mm £11.99
1 x Alpenföhn 120mm Wing Boost Pure Plus PWM - Black £9.95
1 x Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan £8.5
1 x Silverstone 120mm Fan AP122 1200RPM Air Penetrator £4.99
Total : £86.99 (includes shipping : £8.00).
The Silverstone air penetrators are amazing!
im looking for the red and black theme Snips86x
i think ill go with the AF120 for exhaust i also want to change my stock 2 intake fans should i use AF120s, keep in mined my case, it doesnt intake from the front its from the sides
