Hi Guys
We have available for pre order with an ETA of around a week, the brand new fan revisions from Corsair
This is a PWM version of their popular SP120 fans. This is fast becoming a market leading fan with superb performance features as well as impressive statistics.
Within the next few weeks, we will also be moving all of our OcUK Tech Labs Water Cooling kits over to these fans [the non PWM varient] after extensive testing to prove them as good as the Scythe Gentle Typhoons for Watercooling and heatsink applications.
remember, all of these fans come complete with colour accent rings to allow you to change the colours of the fans to match your system
Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Single Pack (CO-9050011-WW) @ £14.99 inc VAT
The wide body, low-pitch blades of the SP120 fans combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable Advanced Hydraulic Bearing, and PWM support for increased fan speed control, the SP120 truly is the strong, silent type.
Included in the box are the three user-replaceable colored rings, in red, blue, and white, so you can customize your fan to match your case’s components. Each fan also features blacked-out wires and connectors, so your build looks elegant and clean when done. Available in single and twin packs.
• The SP120 Quiet Edition, at full RPM, is an extremely quiet 23dBA while maintaining an impressive 1.29mm/H2O static pressure level.
• 4-PIN PWM Support for increased fan speed control
• Custom fan enclosure for ducting air in the right direction with minimal interference.
• Advanced Hydraulic Bearing for reliable, quiet operation.
• Rubberized corners for sound damping when installed with standard screws.
• User-replaceable colored rings so you can match your fans to your case
• Available in single or twin packs.
Only £14.99 inc VAT.
ORDER NOW
Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) @ £25.99 inc VAT
Only £25.99 inc VAT.
ORDER NOW
Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Single Pack (CO-9050013-WW) @ £14.99 inc VAT
Included in the box are the three user-replaceable colored rings, in red, blue, and white, so you can customize your fan to match your case¡¦s components. Each fan also features blacked-out wires and connectors, so your build looks elegant and clean when done. Available in single and twin packs.
• The SP120 High Performance Edition, at full RPM, has outstanding static pressure, up to 3.1mm/H2O, when used on a radiator or heatsink.
• Seven wide body, low-pitch custom blades for optimal static pressure at very low noise levels.
ORDER NOW
Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) @ £25.99 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
