Corsair Graphite 380T Portable Mini ITX Case
rjk
rjk
Caporegime
8 Aug 2007
:D
Another First to Market
OcUK with the Sharpest Pencils once again :cool:
The Graphite Series 380T packs a powerful punch in a portable Mini-ITX PC case. A built-in carrying handle makes transport a breeze. It’s easy to build the road-ready computer of your dreams within a spacious, easy to access interior with room for an extra-long graphics card. You can keep things cool with mounts for up to six fans and a convenient front panel three-speed fan controller.
The Graphite Series 380T Mini-ITX PC case doesn’t make any comprises inside or out. The sleek design derives from Corsair’s most-celebrated computer cases -- featuring eye-catching rounded corners as well as multiple color options. A built-in carrying handle lets you take it anywhere with ease.
Fine-tune air-cooling performance with the three-speed fan controller. Visible through the windowed side panels, the roomy and easy to access interior delivers major real estate for your next rig with space for a full-length graphics card, six fans, and four drives. Plug in your USB 3.0 devices and headset through the front panel. Now you’re ready to hit the road in style.
Features:
- Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
- Built-in carrying handle makes it a portable powerhouse
- Included 140mm LED intake fan and 120mm exhaust fan
- Control freak? Customize cooling and noise level with the convenient three-speed fan controller
- Swap drives easily -- without tools -- in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
- Built-in internal lighting with to show off your system
- Easy connectivity with front panel USB 3.0, headphone, and microphone ports
- Maximum CPU Cooler Height -150mm
- Maximum GPU Length - 290mm
- Maximum PSU Length - 180mm
- Mounts for 5 Fans
- Front fan mounts: 1 x 200/140mm, 2 x 120mm
- Side fan mounts: 2 x 120mm
- Rear fan mounts: 1 x 120mm
Radiator compatibility:
- Front - 140mm or 120mm
- Bottom - 240mm
- Rear - 120mm
Corsair Graphite 380T Portable Mini ITX Case - Black (CC-9011061-WW) @ £99.95 inc VAT
Only £99.95 inc VAT.
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - White (CC-9011060-WW) @ £109.99 inc VAT
Only £109.99 inc VAT.
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - Yellow (CC-9011065-WW) @ £109.99 inc VAT
ORDER NOW
