Corsair Graphite 600T Midi Tower
5 Nov 2010
London
Hi Guys,
Anyone know when the Corsair Graphite 600T Midi Tower Case white Limited Edition is going to be available and if it is a good choice for an asus RE3 build, looks as if there is plenty of room in it?
Many Thanks,
Mole :confused:
Get the 650D instead subject to thicker normal 200mm fans fitting in the front with the hdd cage in something the 600t cannot do.
600t
Hi C64,
Thanks for the quick response, Hmm, just looked at the reviews on the normal 600t and looks like they require the fans replacing as they're not up to much, the 650d is a little more expensive, but outwheighed by the fact the fans are ok that are supplied with it, which would add to the cost of the 600t, I am on a bit of a budget as I need 2 of these (one is for a mate). I like the design of the 600T though. I was also looking at the nzxt hush silent 2 case, but others are saying the build quailty isn't up to much on those cases (bit of a mixed response really) perhaps I could wait a bit longer and decide when the bank manager feels a little more comfortable about spending a few extra reddies?
Regards
Mole :confused:
Apparently the white 600T is fitted with different fans from the older black model, also comes with the mesh side panel you can fit up to 4 120mm fans to. I have heard an eta of between mid April and early May.
One thing that swayed me in the direction of the 600T is the width of the case, it should accommodate a much wider rage of coolers because of that. As for the fan if it is a problem remove the HHD cage and use the 5.25" bays unless you need to fit a lot of HDD's?
I also prefer the look of this case to the 650D ;)
Hi Guys, just looked at the video of the 650d below this thread, looks pretty impressive, but from the details Troezar posted, if the fans are no problem, then i may pre-order a couple of the 600Ts, they do look more pleasing to the eye, and the white ones look that much cooler too!! :) ( Thanks for that bit of info also Ace Modder)
I get to build my m8's one first (practice makes perfect you know!) and then tweek mine to get it right, LOL!!!
600T
Thanks again Troezar, I'll take a look, If I do decide to get this model, I'll post an update on how it goes together, (just to remind me as a "HOW TO" when I do the second one) LOL!!
Regards
Mole:D
