First to Market from what I can see.
The stunning Graphite Series 780T Full-Tower PC case can satisfy the most hardcore computer gamer or overclocker with ample room for nine drives and nearly a dozen large cooling fans. Water-cooling enthusiasts will appreciate the generous space for dual 360mm radiators. The 780T offers easy maintenance shortcuts like tool-free removal of side panels, hard drives, and graphic cards. A three-speed fan control button and generous options for your array of peripherals make the front-panel a true time saver.
A nicely-built high performance PC can be a thing of beauty. This is truer than ever with the sleek, artfully crafted, and undeniably stunning Graphite Series 780T. The striking Graphite Series 780T full tower PC case is the perfect place for your high-end PC parts and delivers a knockout when it comes to performance capabilities and ease of maintenance.
Evade the aesthetics of yesteryear with 780T’s rounded corners and smart design principles inside and out. A windowed side panel reveals incredible expansion and layout options, including space for dual 360mm radiators or up to nine 120mm fans. With room for nine drives thanks to the modular tool-free hard drive cages and side-mounted SSD bays, you’ll have tons of storage flexibility. The front panel offers a lot of functionality, too: a three-mode fan controller makes you the judge of optimal noise and cooling ratios, and there are two ports each for USB 3.0 and 2.0 devices, as well as headphone and microphone ports.
Features:
- Rounded corners and a sleek, cohesive design for great-looking systems
- Latched side panels for easy access
- Supports dual 360mm radiators for state-of-the-art cooling installations
- Front panel three-mode fan controller lets you tailor performance and fan noise
- Dual 140mm LED intake fans and a 140mm exhaust fan for ample airflow
- Six Modular hard drive cages and three space-saving side-mounted SSD bays for smart storage
- Maximum CPU Cooler Height - 200mm
- Maximum GPU Length - 355mm
- Maximum PSU Length - 260mm
Radiator Compatibility:
- Front - 360mm or 280mm
- Top - 360mm or 280mm
- Bottom - 240mm
- Rear - 140mm
Fans:
- Front fan mounts: 3 x 120, 2 x 140 mm
- Top fan mounts: 3 x 120, 2 x 140mm
- Bottom fan mounts (with HDD cage removed): 2 x 120mm
- Rear fan mounts: 1 x 140/120mm
Corsair Graphite 780T Full Tower Case - Black (CC-9011063-WW) @ £139.99 inc VAT
Only £139.99 inc VAT.
ORDER NOW
Corsair Graphite 780T Full Tower Case - White (CC-9011059-WW) @ £144.95 inc VAT
Only £144.95 inc VAT.
ORDER NOW
Corsair Graphite Series Full Tower Case - Yellow (CC-9011064-WW) @ £144.95 inc VAT
ORDER NOW
Features:
- Bottom - 240mm
- Rear - 140mm
Fans:
ORDER NOW
ORDER NOW
ORDER NOW
