I have just received my H100 and i'm considering using my 4 pin PWM fans connected to the block on the H100.
It appears the block has 4 x 4 pin connections for fans but I cannot find anything about if I can plug 4 PWM fans into the block. I'm sure you can but would like some confirmation if anyone has done this yet.
I might still just connect all the fans to run off the PWM fan header on the board as I then have full control over the fan speeds. Will the H100 run ok with no fans connected to it ?
Thanks for listening.
