Ok guys. Basically, i have purchased the corsair hydro 100 and the 400r case.
(Mobo p8z77-v Pro)
When i went to install the rad, it works fine. Gone ahead to install the fans. No problem. Until i noticed.... the 8pin mobo connector is just UNDER the left fan. So i unscrewed the fan, put in the mobo connector in and i was shocked that there is no space to put the fan in properly. Its of by a bit, and the mobo connector is pressed down when i install the left fan, so the 8pin cable leans on the mobos secondary heatsink (the blue one on the left)
Please see link for exact mobo.
http://assets.vr-zone.net/15141/P8Z77_V_pro_1.jpg
Should i send back the case OR the h100 ?
Any other solution?
I would think corsair had thought of everything when they made those two items.
(Mobo p8z77-v Pro)
Any other solution?
