Corsair H100 and Fractal R2 case...
28 Aug 2006
Does anyone know if the Corsair H100 dual rad fit the top mount holes for the 2 top rad grills on the Fractal R2 case?
Iirc, it wont. The R2 doesn't use standard spacings for x2 120mm. The mounting holes are too far apart for the two fans.
If you do have enough space internally,You could just re-drill the holes your self,Or i suppose you could go ghetto and mount it externally on top :p:p
