corsair h100 push/pull
11 Mar 2012
portsmouth
hi all,
can anyone tell me if i can fit h100 into cosmos2 with push pull config.
thanks.
i will be installing new motherboard z77 sabretooth if this makes any difference.
from what i have seen and read rad needs to be inside 2 fans outside and 2 fans below rad not sure if it clear mb.
if anyone has this system pls let me know.
Just take some measurements. The H100 rad is ~26mm iirc, fans are 25mm thick a piece.
H100 + 2 x fan = 76mm
So say for a comfortable fit you want to be looking in the region of 80mm. I would say it should fit, fairly sure I've seen 60mm thick rads in the top of one with one set of fans, that comes to around 85mm.
thanks ill measure it im going to put 2 fans in top compartment so i need about 55mm clearance to mb ?
will my new sabretooth z77 fit in the exact same place as my existing mb.
Should fit, check this video, shows H100 with push pull fans in a Cosmos II.
Edit: Ignore thats for a Cosmos 1000.
Edit 2: Look at this, shows H100 with PP in a cosmos 2 using a larger eATX board (rampage IV)
