Hello all, I recently purchased a white 600t and h100i cooler. How ever I'm having a few problems I can't seem to just "google it". The instructions are also **** poor to say the least.
Anyways, I have installed the 2 supplied fans with the h100i at the top of the grill and mounted the radiator below it (I plan to upgrade the fans). My problem been the H100i comes y fan splitters that should be plugged into the 2 top fans.
However since I have a 600t with a built in fan controller I would prefer to just have all 4 fans including the top grill ones over the h100i plugged into there.
My questions really are will not have the y splitter plugged in at all effect anything and does the USB header need to be plugged in for the corsair software etc. Or is the software and plugging the fans into the control pump a massive performance boost?
Thanks for reading chaps much appreciated!
