**CORSAIR H100i GTX COOLER DEAL**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
We have been offered the chance to give you guys a great cooler at very nice price. The H100i GTX performs the same as the H100i V2 as it is basically a rebrand with a few minor changes including the location of the link cable. As you will be able to see you will be saving £30 over the H100i V2 so it is a nice little saving.
Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler @ £89.99 inc VAT
Socket Compatibility: 1150 / 1151/ 1155 / 1156 / 1366 / 2011 / 2011-3 / AM2 / AM3 / FM1 / FM2
Socket AM4 Bracket available here for free.
Extreme Performance CPU Cooling
Have a PC case that supports a top-mounted 240mm radiator? Take your CPU cooling to a new level. H100i starts with the advanced design of the Hydro Series H80i, and adds a double-wide radiator for even better performance.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Self-contained Cooling System
Hydro Series H100i comes pre-filled, and never needs refilling or priming.
Dual Radiator with Custom Fan Design
The 240mm top-mounted radiator provides maximum surface area for maximum cooling power. The 120mm fans use wide, low-pitch blades for better static pressure to noise ratio, offering improved efficiency at lower noise levels.
Built-In Corsair Link
No additional hardware is necessary – just connect the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link Dashboard software. You can monitor coolant temperature and adjust cooling performance directly from your desktop.
Tool-free multiplatform magnetic mounting bracket kit
The modular design makes installation simpler, and it’s compatible with Intel and AMD processors.
Large-diameter, low permeability tubing
Minimal coolant evaporation helps ensure long life, and the resilient material offers both high flexibility and excellent leak protection.
Features:
- 240mm dual-fan radiator: more surface area for superior cooling performance
- Improved coldplate and pump design: better efficiency gives you lower temperatures with less noise
- Advanced SP120L PWM fan design: better high-static pressure air delivery and customizable speed
- Modular, tool-free mounting bracket: installation is simple and straightforward.
- Built-in Corsair Link: monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
Specification:
- Radiator dimensions: 276mm x 125mm x 30mm
- Fan dimensions: 120mm x 120mm x 25mm
- Fan speed: 2435 +/- 10% RPM
- Fan airflow: 70.69 CFM
- Fan static pressure: 4.65 mmH2O
- Fan noise level: 37.7 dB(A)
- Warranty: 2 Years
Only £89.99 inc VAT.
ORDER NOW
If you like the above cooler but fancy RGB then we have the H100 RGB Extreme Performance Liquid Cooler at the same price currently of £89.99.
Corsair H100 RGB Extreme Performance Liquid Cooler **OcUK Exclusive** @ £89.99 inc VAT
Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ AM2 / AM2+ / AM3/ FM1 / FM2 / Ryzen
Liquid cooling works better than air cooling, and the self-contained design of the H100 gets you up and running quickly so you can spend more time enjoying the performance of your overclocked processor and less time assembling, filling, and maintaining your cooling system.
The Corsair SP120 RGB LED high performance PC case fans combine excellent air delivery with hub mounted RGB LEDs and translucent, frosted fan blades for brilliant lighting. By utilizing ultra-thin fan blades the SP120 RGB LED fans are custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. Each fan offers bold lighting with vivid lighting effects.
Features:
- Large 240mm radiator: more cooling capacity
- Advanced SP120 RGB PWM fan design: better high-static pressure air delivery and customizable speed
Cooler Specification:
Fan Specification
- Fan Dimensions: 120 x 120 x 25
- Rated Voltage: 12v
- Speed: 1400 +/- 10%
- Airflow: 52 cfm
- Static Pressure: 1.45 mm-H2O
- Sound Level: 26 dBa
- Connection Cable: 3 pin
- PWM Control: No
- Bearing Type: Hydraulic
- Cable Length: 600mm
Box Contents:
- Corsair Hydro Series H100 OEM
- Mounting kit for all modern CPU sockets
- Intel, AMD, Ryzen Compatible
- Two SP120 RGB 120mm fans
- RGB Controller
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
Was £99.95 inc VAT.
Now £89.99 inc VAT.
ORDER NOW
To use any other thermal paste you would need to remove the pre applied stuff first which is easy to remove.
Thanks Robbie_G currently using a Corsair H45 which is way too noisy. Looking forward to the reviews for this one :)
p.s. It says you're a Gangster in your profile?
The reviews are already out as this an old model now as it was rebranded and called the H100i V2 when they rebranded most of the range.
Part of the Overclockers Mafia.
