Hi,
Have noticed over the past few days whilst gaming the Corsair logo on the pump keeps flashing red even though Coretemp shows my temps around 45-50 degrees. (there is a difference of 10 degrees between BIOS temps & software temps so 60 degrees tops)
Checking BIOS the pump also shows 0rpm (tried both fan headers) installed the Corsair Link software and this shows the pump is running @ 2000rpm (normally 2800 - 3000rpm in BIOS) The pump is working as you can hear it buzz.
Fans are blowing cool to warmish air out of my case so any ideas why?
thanks.
thanks.
