Corsair H115i Pro Cooler issue
5 Oct 2020
Just installed a Corsair liquid cooler but can not get the RGB on the pump to work AT all, tried connecting sata connector to another cable, tried updating bios....nothing i've tried has worked the pump itself is working, system is at 22c idle so its just the lighting. Anyone have any ideas i can try please? I really don't want to have to take it out and get a new one to install 'cos it was a major pain.
Thanks in advance.
Have you installed iCUE and checked the lighting/settings there?
Had the same problem with some LL120 fans I installed recently, thought the RGB was DOA... Turns out iCUE had somehow defaulted the LEDs off.
Yeah, thanks for your reply, i've been messing with iCUE it for ages now and its working with my other Corsair stuff but not the pump. I've ordered a new usb cable but i dont think its going to be that. I think its a fault with the pump, just a bad feeling I have. I rreally dont want to take it all apart again to swap it out.
