Anybody know what the difference is between Corsair h115i vs h110i v2?
Nope, they're definitely both 280mm.H115i is 280mm H110i v2 is 240mm
take another look bud.....h100i v2 is 240mm, h115i is 280mm, straight from corsair website....
H100i V2: http://www.corsair.com/en-gb/hydro-series-h100i-v2-extreme-performance-liquid-cpu-cooler
H115i: http://www.corsair.com/en-gb/hydro-series-h115i-280mm-extreme-performance-liquid-cpu-cooler
Hi,
The H115i is basically an updated version of the H110i. The H115i has better tubing and CPU block as well as improved cooling from a slightly better designed radiator.
