- 26 Sep 2013
- Leicester
I have a Question about the Corsair H40 Water Cooling Unit.
It comes fitted with a Single 120mm x 25mm fan.
My question is can it be fitted with 2 ( fan 25mm+Rad 25mm+Fan 25mm)
If so would this Improve cooling more than it would with 1.
I have seen setups using Different Non Corsair Sealed Units that use 2 fans on a 120mm Rad.
I was just wondering if it Worked and if there was any Real Benefit from it.
