Good evening all,
I recently got the above cooler.
Didnt have much trouble installing it was fairly easy, however im not sure if its working properly.
I am not the most tech person around, so i was hoping to get some advise if possible.
I have an i7 940 2.93, it isnt overclocked just standard. Before i installed this water cooler my cpu temp was running around 55-60 whilst gaming, and idle 32-41. With the cooler installed i played a game and my temp run up to 60-65, and at some points the game started jerking and slow down.
Is there any way of checking how much power is going to the pump? or to give it more power?
http://www.asus.com/Motherboards/Intel_Socket_1366/P6T_Deluxe/
Thats my current MB. Just dont feel its working as good as it should be.
Any suggestions would be most welcome.
) that a similar thing would be needed here. As the previous poster said you can change the settings in your BIOS on the page mentioned in the manual to suit your needs.
should have just kept my old fan.
