I'd need to check the dimensions of the h50 but yes in the front would be the only option, unless you want it outside the case. I'll be posting my 350 rebuild over on chilled this weekend as just got my 460 cyclone this morning ;D so if you want any measurments of the internals of the case just gimme a shout
I've seen some one else with one, I forget his name though, and he just cut out a bit from the bottom of the optical drive bay area. So I think I might do that same as that.
yeh that should work fine, depending on the height of the rad you might even be able to cut out the part of the ledge at the bottom of the fan bracket and mount it that way
