Corsair H50 parts
30 Jul 2007
Surrey
Hi,
I need a new backplate for my corsair H50 and hopefully four new screws (so as to add another fan) - how is this most easily achieved? Is phoning Corsair the easiest/best solution?
Cheers,
Alex
anyone know if you can still get the brackets spare need the 775 plastic b racket and back plate :rolleyes: and the links on the previous post are blank now
I didnt bother buying new screws for push pull, i just used two for each fan diagonally opposite, holds fine, no rattle or anything
Wish I knew where to get one as well. Started putting my i7 system together only to be stopped by a missing backplate. I think I accidently sold it still attached to my old pc :P
Really annoying how they made the fittings about 5mm wider than the 1156 so a standard 1156 backplate wont fit a 1155 :/
i have had no luck finding one of these , my h50 as the older type brackets where their was 1 for amd ,one for 775 and one for i7 , but i lost my 775 mounting bracket the plastic one that sits on the cpu and the cooling head goes into , what a bumber :( now i cant use it on my 775 board
