Corsair H50 question?
30 Mar 2009
Hi Guys,
I have been trying to find out the type of screws the corsair H50 uses for mounting the fans to the unit as I want to do a push/pull set-up to increase the airflow through the radiator, any advice would be appreciated.
Cheers
Q: I want to run push/pull, what screws will I need for a second fan?
A: The screw thread and length are 6 x 32 x 1 1/4"
Taken from here
I had difficulty finding this thread and length in my local hardware shops, so I used self tappers of the same length... did me... however the rad is ally, so it would need to be a close fit, so as not to split the rad!!
Worked for me,but not a recomendation
Taken from here
Correct, but it should read 6 x 32 UNC (the correct thread form). This is the same for hard drives and some cases.
Its a rare thread in the UK so local shops / DIY shops etc will not have them.
brilliant thanks, Ordered and on their way as well as an additional akasa viper to do the old push and some MX3 thermal paste to seal the deal, I checked how much was on the corsair device as standard and lets just say it was enough to glue the cooler onto the processor without the bracket! so thats getting cleaned off and some MX3 thinly applied :)
