Corsair H50 Questions
It only ships with 775 and 1366 fittings. Corsair will supply you with fittings for the cost of postage (i think? / pretty sure).
I haven't seen anyone using a h50 on a phenom but it's doing what it's supposed to on my i7. I think your TDP is similar / lower so it should be fine. What case will you be using?
I am using a fairly generic case, but its not cluttered.
Not being supplied with the AM2+ bracket is a turn off. I shall look into getting a nice air-cooling system
Thanks for the info.
