27 Oct 2009 at 12:04 #1 manbearpig manbearpig Associate Joined 21 Oct 2009 Posts 1,485 Location Bedfordshire is the 120mm fan that comes with the H50 attached to the radiator or can i change the fan? thanks
27 Oct 2009 at 12:07 #2 game4it game4it Associate Joined 27 Nov 2008 Posts 371 Location Dublin,Ireland manbearpig said: is the 120mm fan that comes with the H50 attached to the radiator or can i change the fan? thanks Click to expand... Its seperate so you can use any 120mm fans you want.The unit only comes with 4 screws though.
