Hi All
I noticed something the other day on the radiator of my H50. I had to remove it from my case to clear out the dust from the rad as my bro decided to put my shelf up and not cover my case so got a bit dusty.
There was some residue on the radiator next to where the barbs and pipes are, i cleaned it off and it was like some type of oil/grease is it anything to worry about.
I have noticed that my H50 makes a little bit of noise when i power up pc just sounds like the water sucking through.
