Hi Everyone
I am shortly going to be replacing my old CPU cooler with a corsair H70 and I am looking for some advice as to whether I would be better off mounting it as an intake or an exhaust.
My case is a coolermaster stacker stc-t01 with the following current fan setup:
2x 80mm bottom rear fans - exhaust
1x 80mm top fan - exhaust
1x crossflow fan - intake
1x front 120mm fan - intake
1x left panel 80mm fan - exhaust
1x top rear 120mm fan - exhaust
The rest of my setup is in my signature
All fans are noctua (barring the cross flow fan obviously) - the 120mm are nf-p12's and I cannot remember the model of the 80mm
I would be mounting the H70 radiator in place of the rear exhaust fan, but I am not sure whether my case would suit an intake or exhaust setup more. I could not find a unified answer to this question by searching so I thought I might get a better response if I put the question in the context of my specific case setup.
Hope you can help
Thanks!
Hope you can help
Thanks!
